cluster log-forwarding show
Display log forwarding destinations
The cluster log-forwarding show command displays log forwarding information:
Destination (IPv4/IPv6/hostname)
Port number
List of log classes
Facility
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-destination <Remote InetAddress>]- Destination Host-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified host name, IPv4 or IPv6 address.
[-port <integer>]- Destination Port-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified ports.
[-protocol {udp-unencrypted|tcp-unencrypted|tcp-encrypted}]- Log Forwarding Protocol-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified protocols.
[-verify-server {true|false}]- Verify Destination Server Identity-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified verify-server values.
[-facility <Syslog Facility>]- Syslog Facility-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified facility.
cluster-1::> cluster log-forwarding show Verify Syslog Destination Host Port Protocol Server Facility ------------------------ ------ --------------- ------ -------- 192.168.0.1 514 udp-unencrypted false user
