cluster log-forwarding show
Display log forwarding destinations
The cluster log-forwarding show command displays log forwarding information:
Destination (IPv4/IPv6/hostname)
Port number
List of log classes
Facility
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-destination <Remote InetAddress>]- Destination Host-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified host name, IPv4 or IPv6 address.
[-port <integer>]- Destination Port-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified ports.
[-protocol {udp-unencrypted|tcp-unencrypted|tcp-encrypted}]- Log Forwarding Protocol-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified protocols.
[-ipspace <IPspace>]- IPspace of Destination-
If this optional parameter is specified, the command displays information about the IPspace to which the forwarding destinations belong.
[-verify-server {true|false}]- Verify Destination Server Identity-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified verify-server values.
[-facility <Syslog Facility>]- Syslog Facility-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified facility.
[-message-format {legacy-netapp|rfc-5424}]- Syslog Message Format-
Use this optional parameter to display information about the Syslog destination that has the specified Syslog message format.
[-timestamp-format-override {no-override|rfc-3164|iso-8601-utc|iso-8601-local-time}]- Syslog Timestamp Format Override-
Use this optional parameter to display information about the Syslog destination that has the specified Syslog timestamp format override.
[-hostname-format-override {no-override|fqdn|hostname-only}]- Syslog Hostname Format Override-
Use this optional parameter to display information about the Syslog destination that has the specified Syslog hostname format override.
The following example displays information about the log forwarding
cluster-1::> cluster log-forwarding show
Verify Syslog
Destination Host Port Protocol Server Facility
192.168.0.1 514 udp-unencrypted false user
cluster-1::> cluster log-forwarding show -instance
Destination Host: 192.168.0.1
Destination Port: 514
Log Forwarding Protocol: udp-unencrypted
IPspace of Destination: Default
Verify Destination Server Identity: false
Syslog Facility: user
Syslog Message Format: legacy-netapp
Syslog Timestamp Format Override: no-override
Syslog Hostname Format Override: no-override
