Command reference
cluster log-forwarding show
Display log forwarding destinations
The cluster log-forwarding show command displays log forwarding information:
  • Destination (IPv4/IPv6/hostname)
  • Port number
  • List of log classes
  • Facility
{ [-fields <fieldname>,…​]
| [-instance ] }
[-destination <Remote InetAddress>] - Destination Host
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified host name, IPv4 or IPv6 address.
[-port <integer>] - Destination Port
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified ports.
[-protocol {udp-unencrypted|tcp-unencrypted|tcp-encrypted}] - Log Forwarding Protocol
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified protocols.
[-ipspace <IPspace>] - IPspace of Destination
If this optional parameter is specified, the command displays information about the IPspace to which the forwarding destinations belong.
[-verify-server {true|false}] - Verify Destination Server Identity
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified verify-server values.
[-facility <Syslog Facility>] - Syslog Facility
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified facility.
[-message-format {legacy-netapp|rfc-5424}] - Syslog Message Format
Use this optional parameter to display information about the Syslog destination that has the specified Syslog message format.
[-timestamp-format-override {no-override|rfc-3164|iso-8601-utc|iso-8601-local-time}] - Syslog Timestamp Format Override
Use this optional parameter to display information about the Syslog destination that has the specified Syslog timestamp format override.
[-hostname-format-override {no-override|fqdn|hostname-only}] - Syslog Hostname Format Override
Use this optional parameter to display information about the Syslog destination that has the specified Syslog hostname format override.
The following example displays information about the log forwarding
cluster-1::> cluster log-forwarding show
Verify  Syslog
Destination Host         Port   Protocol        Server  Facility
192.168.0.1              514    udp-unencrypted false   user
cluster-1::> cluster log-forwarding show -instance
Destination Host: 192.168.0.1
                   Destination Port: 514
            Log Forwarding Protocol: udp-unencrypted
             IPspace of Destination: Default
 Verify Destination Server Identity: false
                    Syslog Facility: user
              Syslog Message Format: legacy-netapp
   Syslog Timestamp Format Override: no-override
    Syslog Hostname Format Override: no-override
