cluster log-forwarding show
Display log forwarding destinations
The cluster log-forwarding show
command displays log forwarding information:
Destination (IPv4/IPv6/hostname)
Port number
List of log classes
Facility
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-destination <Remote InetAddress>]
- Destination Host-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified host name, IPv4 or IPv6 address.
[-port <integer>]
- Destination Port-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified ports.
[-protocol {udp-unencrypted|tcp-unencrypted|tcp-encrypted}]
- Log Forwarding Protocol-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified protocols.
[-ipspace <IPspace>]
- IPspace of Destination-
If this optional parameter is specified, the command displays information about the IPspace to which the forwarding destinations belong.
[-verify-server {true|false}]
- Verify Destination Server Identity-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified verify-server values.
[-facility <Syslog Facility>]
- Syslog Facility-
If this optional parameter is specified, the command displays information about the forwarding destinations with the specified facility.
[-message-format {legacy-netapp|rfc-5424}]
- Syslog Message Format-
Use this optional parameter to display information about the Syslog destination that has the specified Syslog message format.
[-timestamp-format-override {no-override|rfc-3164|iso-8601-utc|iso-8601-local-time}]
- Syslog Timestamp Format Override-
Use this optional parameter to display information about the Syslog destination that has the specified Syslog timestamp format override.
[-hostname-format-override {no-override|fqdn|hostname-only}]
- Syslog Hostname Format Override-
Use this optional parameter to display information about the Syslog destination that has the specified Syslog hostname format override.
The following example displays information about the log forwarding cluster-1::> cluster log-forwarding show Verify Syslog Destination Host Port Protocol Server Facility ------------------------ ------ --------------- ------ -------- 192.168.0.1 514 udp-unencrypted false user cluster-1::> cluster log-forwarding show -instance Destination Host: 192.168.0.1 Destination Port: 514 Log Forwarding Protocol: udp-unencrypted IPspace of Destination: Default Verify Destination Server Identity: false Syslog Facility: user Syslog Message Format: legacy-netapp Syslog Timestamp Format Override: no-override Syslog Hostname Format Override: no-override
