vserver cifs domain discovered-servers discovery-mode modify
PDF of this doc site
Creating your file...
Modify Server Discovery Mode
The vserver cifs domain discovered-servers discovery-mode modify
command modifies the configuration for the server discovery mode of one or more Data Vservers. This option controls the way domain controllers(DCs) are discovered.
-vserver <vserver name>
- Vserver (privilege: advanced)-
Use this parameter to specify the Vserver for which you want to modify the server discovery mode.
[-mode {all|site|none}]
- Server Discovery Mode (privilege: advanced)-
Use this parameter to specify the server discovery mode for the Vserver. Following are the possible values for this parameter:
all - Discover all the DCs in the domain (default).
site - Discover the DCs local to the site.
none - Discover nothing. Depend only on preferred-dc configured.
The following example disables server discovery for a Vserver.
cluster1::> vserver cifs domain discovered-servers discovery-mode modify -vserver vs1 -mode none
