system controller flash-cache secure-erase run
Perform a secure-erase operation on the targeted devices
The system controller flash-cache secure-erase run command securely erases the givien Flash Cache device.
-node {<nodename>|local} - Node
Selects the node of the specified Flash Cache devices.
-device-id <integer> - Device Id
Selects the device-id of the specified Flash Cache devices.
The following example securely erases the selected Flash Cache device:
cluster1::> system controller flash-cache secure-erase -node node1 -device-id 0
