The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snaplock event-retention show-vservers
PDF of this doc site
Creating your file...
Your file is ready
Show Vservers with SnapLock Event Based Retention policies
The snaplock event-retention show-vservers
command is used to display the Vservers that have SnapLock Event Based Retention (EBR) policies created.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
The following example displays all Vservers that have SnapLock EBR policies:
cluster-1::*> snaplock event-retention show-vservers Vserver ----------------- vs1
