      snaplock event-retention show-vservers
Show Vservers with SnapLock Event Based Retention policies
The snaplock event-retention show-vservers command is used to display the Vservers that have SnapLock Event Based Retention (EBR) policies created.
[-fields <fieldname>,…]-
If you specify the
-fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
The following example displays all Vservers that have SnapLock EBR policies:
cluster-1::*> snaplock event-retention show-vservers
        Vserver
        vs1
