ONTAP commands
system service-processor network show
Display the network configuration
The system service-processor network show command displays the network configuration of the Service Processor of each node in a cluster. You can limit output to specific types of information and specific nodes in the cluster, or filter output by specific field values.
In case a node is offline or its Service Processor management daemon is down, the command displays the last known IP address of its Service Processor. Only the IP address is displayed in such cases.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects network configuration information for the Service Processor of the specified node.
[-address-family {IPv4|IPv6}] - Address Family
Selects network configuration information for the Service Processors that have the specified IP address family.
[-enable {true|false}] - Interface Enabled
Selects network configuration information for the Service Processors whose network interface for the given address-family is enabled or disabled as specified.
[-type {SP|NONE|BMC}] - Type of Device
Selects network configuration information for the Service Processors of the specified type.
[-status {online|offline|sp-daemon-offline|node-offline|degraded|rebooting|unknown|updating}] - Status
Selects network configuration information for the Service Processors whose status matches the specified value.
[-link-status {up|down|disabled|unknown}] - Link Status
Selects network configuration information for the Service Processors whose link status matches the specified value.
[-dhcp {v4|none}] - DHCP Status
Selects network configuration information for the Service Processors whose DHCP status matches the specified value.
[-ip-address <IP Address>] - IP Address
Selects network configuration information for the Service Processors that use the specified IP address.
[-mac <MAC Address>] - MAC Address
Selects network configuration information for the Service Processors that use the specified MAC address.
[-netmask <IP Address>] - Netmask
This parameter displays information only for the Service Processors that use the specified netmask.
[-prefix-length <integer>] - Prefix Length of Subnet Mask
Selects network configuration information for the Service Processors whose prefix length of subnet mask matches the specified value.
[-router-ip <IP Address>] - Router Assigned IP Address
Selects network configuration information for the Service Processors whose router-assigned IP address matches the specified value.
[-link-local-ip <IP Address>] - Link Local IP Address
Selects network configuration information for the Service Processors whose link local IP address matches the specified value.
[-gateway <IP Address>] - Gateway IP Address
Selects network configuration information for the Service Processors whose gateway IP address matches the specified value.
[-time-last-updated <text>] - Time Last Updated
Selects network information for the Service Processors that have the specified time stamp showing when configuration was last updated.
[-subnet-name <text>] - Subnet Name
Selects network information for the Service Processors that use the specified subnet-name for SP automatic configuration.
[-is-ipv6-ra-enabled {true|false}] - Enable IPv6 Router Assigned Address
Selects network information for the Service Processors that have the specified status for IPv6 router-assigned address.
[-setup-status {not-setup|succeeded|in-progress|failed}] - SP Network Setup Status
Selects network information for the Service Processors that have the specified status for network interface setup.
[-setup-failure-reason {success|subnet-out-of-address|invalid-subnet|other-error}] - SP Network Setup Failure Reason
Selects network information for the Service Processors that have the specified reason for network interface setup failure.
The following example displays basic network configuration information for the Service Processors of all the nodes.
cluster1::> system service-processor network show
                             Address
Node          Status         Type      Link State  IP Address
node1         online         IPv4      up          192.168.1.201
DHCP: v4
                          MAC Address: ab:cd:ef:fe:ed:01
                      Network Gateway: 192.168.1.1
             Network Mask (IPv4 only): 255.255.255.0
            Prefix Length (IPv6 only): -
          IPv6 RA Enabled: -
                          Subnet Name: -
              SP Network Setup Status: succeeded
node1         online         IPv6      disabled    -
DHCP: none
                      Network Gateway: -
             Network Mask (IPv4 only): -
          IPv6 RA Enabled: -
                          Subnet Name: -
              SP Network Setup Status: not-setup
node2         online         IPv4      up          192.168.1.202
DHCP: v4
                          MAC Address: ab:cd:ef:fe:ed:02
          IPv6 RA Enabled: -
                          Subnet Name: -
node2         online         IPv6      disabled    -
DHCP: none
                      Network Gateway: -
          IPv6 RA Enabled: -
                          Subnet Name: -
4 entries were displayed.
cluster1::>
The following example displays all available network configuration information for the Service Processors of all the nodes.
cluster1::> system service-processor network show -instance
Node: node1
                 Address Family: IPv4
            Interface Enabled: true
               Type of Device: SP
                       Status: online
                  Link Status: up
                  DHCP Status: v4
                   IP Address: 192.168.1.201
                      Netmask: 255.255.255.0
 Prefix Length of Subnet Mask: -
   Router Assigned IP Address: -
        Link Local IP Address: -
           Gateway IP Address: 192.168.1.1
      Time Last Updated: Fri Jun 13 17:03:59 GMT 2014
                  Subnet Name: -
Enable IPv6 Router Assigned Address: -
SP Network Setup Failure Reason: -
Node: node1
                 Address Family: IPv6
            Interface Enabled: false
               Type of Device: SP
                       Status: online
                  Link Status: disabled
                  DHCP Status: none
                   IP Address: -
                      Netmask: -
           Gateway IP Address: -
                  Subnet Name: -
Node: node2
               Type of Device: SP
                       Status: online
                  Link Status: up
                  DHCP Status: v4
                   IP Address: 192.168.1.202
                  Subnet Name: -
Node: node2
               Type of Device: SP
                       Status: online
                  DHCP Status: none
                   IP Address: -
                      Netmask: -
                  Subnet Name: -
cluster1::>
