system node virtual-machine disk-object-store modify
Modify the configuration of an object store
The system node virtual-machine disk-object-store modify command updates one or more object store configuration parameters.
-node <nodename> - ONTAP Node Name
Specifies the name of the ONTAP node for which the object store configuration will be modified.
-object-store-name <object store name> - ONTAP Name for this Object Store Config
Specifies the name that will be used to identify the object store configuration.
[-server <text>] - Fully Qualified Domain Name of the Object Store Server
This optional parameter specifies the new Fully Qualified Domain Name (FQDN) of the same object store server.
[-azure-private-key <text>] - Azure Storage Account Access Key
This optional parameter specifies a new access key for the storage account.
[-update-partner <true>] - Update HA Partner
Specify this parameter when the system is running in an HA configuration.
The following example updates the stored private key for an Azure container on the specified node.
cluster1::*> system node virtual-machine disk-object-store modify
                 -node node1 -object-store-name objstore1
                 -azure-private-key XpSUcS/f1sl4sHfDuzYeyU3Yz9dNqVEsxDv48/P8Zk8j0uDoWYnsf/8JBhlHImH/RP9IO6maKLYqEXAMPLEKEY== -update-partner
