system node virtual-machine disk-object-store modify
Modify the configuration of an object store
The system node virtual-machine disk-object-store modify command updates one or more object store configuration parameters.
-node <nodename>- ONTAP Node Name (privilege: advanced)-
Specifies the name of the ONTAP node for which the object store configuration will be modified.
 -object-store-name <object store name>- ONTAP Name for this Object Store Config (privilege: advanced)-
Specifies the name that will be used to identify the object store configuration.
 [-server <text>]- Fully Qualified Domain Name of the Object Store Server (privilege: advanced)-
This optional parameter specifies the new Fully Qualified Domain Name (FQDN) of the same object store server.
 [-azure-private-key <text>]- Azure Storage Account Access Key (privilege: advanced)-
This optional parameter specifies a new access key for the storage account.
 [-update-partner <true>]- Update HA Partner (privilege: advanced)-
Specify this parameter when the system is running in an HA configuration.
The following example updates the stored private key for an Azure container on the specified node.
cluster1::*> system node virtual-machine disk-object-store modify
                 -node node1 -object-store-name objstore1
                 -azure-private-key XpSUcS/f1sl4sHfDuzYeyU3Yz9dNqVEsxDv48/P8Zk8j0uDoWYnsf/8JBhlHImH/RP9IO6maKLYqEXAMPLEKEY== -update-partner
