The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port vip show
PDF of this doc site
Creating your file...
Your file is ready
Display VIP ports
The network port vip show
command displays information about VIP ports.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
This parameter selects the VIP ports that match the specified node.
[-port <netport>]
- Network Port-
This parameter selects the VIP ports that match the specified port.
[-ipspace <IPspace>]
- IPspace Name-
This parameter selects the VIP ports that match the specified IPspace.
The example below shows VIP port v0a is created in IPspace ips on node1.
cluster1::> network port vip show Node VIP Port IPspace ------ -------- ------------- node1 v0a ips
