ONTAP commands
network port vip show
Display VIP ports
The network port vip show command displays information about VIP ports.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
This parameter selects the VIP ports that match the specified node.
[-port <netport>] - Network Port
This parameter selects the VIP ports that match the specified port.
[-ipspace <IPspace>] - IPspace Name
This parameter selects the VIP ports that match the specified IPspace.
The example below shows VIP port v0a is created in IPspace ips on node1.
cluster1::> network port vip show
    Node   VIP Port IPspace
    node1  v0a      ips
