network port vip show
Display VIP ports
The network port vip show
command displays information about VIP ports.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
This parameter selects the VIP ports that match the specified node.
[-port <netport>]
- Network Port-
This parameter selects the VIP ports that match the specified port.
[-ipspace <IPspace>]
- IPspace Name-
This parameter selects the VIP ports that match the specified IPspace.
The example below shows VIP port v0a is created in IPspace ips on node1.
cluster1::> network port vip show Node VIP Port IPspace ------ -------- ------------- node1 v0a ips
