network port vip show
Display VIP ports
The network port vip show command displays information about VIP ports.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
This parameter selects the VIP ports that match the specified node.
[-port <netport>]- Network Port-
This parameter selects the VIP ports that match the specified port.
[-ipspace <IPspace>]- IPspace Name-
This parameter selects the VIP ports that match the specified IPspace.
The example below shows VIP port v0a is created in IPspace ips on node1.
cluster1::> network port vip show
Node VIP Port IPspace
node1 v0a ips
