Command reference
statistics nfs show-v41
Display NFSv4.1 statistics
The statistics nfs show-v41 command displays the following statistics about the NFSv4.1 operations on each node in the cluster:
  • Result of the operations (success or failure)
  • Total number of null operations
  • Total number of compound operations
  • Total number of access operations
  • Total number of close operations
  • Total number of commit operations
  • Total number of create operations
  • Total number of delegpurge operations
  • Total number of delegret operations
  • Total number of getattr operations
  • Total number of getfh operations
  • Total number of link operations
  • Total number of lock operations
  • Total number of lockt operations
  • Total number of locku operations
  • Total number of lookup operations
  • Total number of lookupp operations
  • Total number of nverify operations
  • Total number of open operations
  • Total number of openattr operations
  • Total number of openconf operations
  • Total number of opendowng operations
  • Total number of putfh operations
  • Total number of putpubfh operations
  • Total number of putrootfh operations
  • Total number of read operations
  • Total number of readdir operations
  • Total number of readlink operations
  • Total number of remove operations
  • Total number of rename operations
  • Total number of renew operations
  • Total number of restorefh operations
  • Total number of savefh operations
  • Total number of secinfo operations
  • Total number of setattr operations
  • Total number of setcliid operations
  • Total number of setcliidconf operations
  • Total number of verify operations
  • Total number of write operations
  • Total number of rellockown operations
  • Total number of total operations
  • Percent of null operations
  • Percent of compound operations
  • Percent of access operations
  • Percent of close operations
  • Percent of commit operations
  • Percent of create operations
  • Percent of delegpurge operations
  • Percent of delegret operations
  • Percent of getattr operations
  • Percent of getfh operations
  • Percent of link operations
  • Percent of lock operations
  • Percent of lockt operations
  • Percent of locku operations
  • Percent of lookup operations
  • Percent of lookupp operations
  • Percent of nverify operations
  • Percent of open operations
  • Percent of openattr operations
  • Percent of openconf operations
  • Percent of opendowng operations
  • Percent of putfh operations
  • Percent of putpubfh operations
  • Percent of putrootfh operations
  • Percent of read operations
  • Percent of readdir operations
  • Percent of readlink operations
  • Percent of remove operations
  • Percent of rename operations
  • Percent of renew operations
  • Percent of restorefh operations
  • Percent of savefh operations
  • Percent of secinfo operations
  • Percent of setattr operations
  • Percent of setcliid operations
  • Percent of setCliidconf operations
  • Percent of verify operations
  • Percent of write operations
  • Percent of rellockown operations
This command is designed to be used to analyze performance characteristics and to help diagnose issues.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If you specify this parameter, the command displays NFSv4.1 statistics only for the specified node.
[-result {success|failure|all}] - Result
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified result (success/failure/all).
[-null <Counter with Delta>] - Null Procedure
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of null operations.
[-cmpnd <Counter with Delta>] - Compound Procedure
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of compound operations.
[-access <Counter with Delta>] - Access Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of access operations.
[-close <Counter with Delta>] - Close Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of close operations.
[-commit <Counter with Delta>] - Commit Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of commit operations.
[-create <Counter with Delta>] - Create Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of create operations.
[-delpur <Counter with Delta>] - Delegpurge Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of delegpurge operations.
[-delrtn <Counter with Delta>] - Delegret Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of delegret operations.
[-gattr <Counter with Delta>] - GetAttr Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of getattr operations.
[-getfh <Counter with Delta>] - GetFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of getfh operations.
[-link <Counter with Delta>] - Link Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of link operations.
[-lock <Counter with Delta>] - Lock Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lock operations.
[-lockt <Counter with Delta>] - LockT Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lockt operations.
[-locku <Counter with Delta>] - LockU Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of locku operations.
[-lookup <Counter with Delta>] - Lookup Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lookup operations.
[-lookpp <Counter with Delta>] - LookupP Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lookupp operations.
[-nverfy <Counter with Delta>] - Nverify Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of nverify operations.
[-open <Counter with Delta>] - Open Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of open operations.
[-opattr <Counter with Delta>] - OpenAttr Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of openattr operations.
[-opconf <Counter with Delta>] - OpenConf Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of openconf operations.
[-opndg <Counter with Delta>] - OpenDowng Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of opendowng operations.
[-putfh <Counter with Delta>] - PutFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of putfh operations.
[-putpfh <Counter with Delta>] - PutPubFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of putpubfh operations.
[-putrfh <Counter with Delta>] - PutRootFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of putrootfh operations.
[-read <Counter with Delta>] - Read Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of read operations.
[-readdr <Counter with Delta>] - ReadDir Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of readdir operations.
[-rlink <Counter with Delta>] - ReadLink Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of readlink operations.
[-remove <Counter with Delta>] - Remove Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of remove operations.
[-rename <Counter with Delta>] - Rename Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of rename operations.
[-renew <Counter with Delta>] - Renew Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of renew operations.
[-restfh <Counter with Delta>] - RestoreFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of restorefh operations.
[-savefh <Counter with Delta>] - SaveFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of savefh operations.
[-secinf <Counter with Delta>] - SecInfo Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of secinfo operations.
[-sattr <Counter with Delta>] - SetAttr Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of setattr operations.
[-sclid <Counter with Delta>] - SetCliId Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of setcliid operations.
[-scidc <Counter with Delta>] - SetCliIdConf Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of setcliidconf operations.
[-verify <Counter with Delta>] - Verify Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of verify operations.
[-write <Counter with Delta>] - Write Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of write operations.
[-relown <Counter with Delta>] - RelLockOwn Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of rellockown operations.
[-total <Counter64 with Delta>] - Total Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of total nfsv4.1 operations.
[-null-pct <Counter with Delta>] - Percent Null Procedure
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of null operations.
[-cmpnd-pct <Counter with Delta>] - Percent Compound Procedure
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of compound operations.
[-access-pct <Counter with Delta>] - Percent Access Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of access operations.
[-close-pct <Counter with Delta>] - Percent Close Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of close operations.
[-commit-pct <Counter with Delta>] - Percent Commit Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of commit operations.
[-create-pct <Counter with Delta>] - Percent Create Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of create operations.
[-delpur-pct <Counter with Delta>] - Percent Delegpurge Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of delegpurge operations.
[-delrtn-pct <Counter with Delta>] - Percent Delegret Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of delegret operations.
[-gattr-pct <Counter with Delta>] - Percent GetAttr Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of getattr operations.
[-getfh-pct <Counter with Delta>] - Percent GetFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of getfh operations.
[-link-pct <Counter with Delta>] - Percent Link Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of link operations.
[-lock-pct <Counter with Delta>] - Percent Lock Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lock operations.
[-lockt-pct <Counter with Delta>] - Percent LockT Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lockt operations.
[-locku-pct <Counter with Delta>] - Percent LockU Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of locku operations.
[-lookup-pct <Counter with Delta>] - Percent Lookup Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lookup operations.
[-lookpp-pct <Counter with Delta>] - Percent LookupP Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lookupp operations.
[-nverfy-pct <Counter with Delta>] - Percent Nverify Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of nverify operations.
[-open-pct <Counter with Delta>] - Percent Open Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of open operations.
[-opattr-pct <Counter with Delta>] - Percent OpenAttr Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of openattr operations.
[-opconf-pct <Counter with Delta>] - Percent OpenConf Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of openconf operations.
[-opndg-pct <Counter with Delta>] - Percent OpenDowng Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of opendowng operations.
[-putfh-pct <Counter with Delta>] - Percent PutFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of putfh operations.
[-putpfh-pct <Counter with Delta>] - Percent PutPubFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of putpubfh operations.
[-putrfh-pct <Counter with Delta>] - Percent PutRootFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of putrootfh operations.
[-read-pct <Counter with Delta>] - Percent Read Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of read operations.
[-readdr-pct <Counter with Delta>] - Percent ReadDir Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of readdir operations.
[-rlink-pct <Counter with Delta>] - Percent ReadLink Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of readlink operations.
[-remove-pct <Counter with Delta>] - Percent Remove Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of remove operations.
[-rename-pct <Counter with Delta>] - Percent Rename Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of rename operations.
[-renew-pct <Counter with Delta>] - Percent Renew Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of renew operations.
[-restfh-pct <Counter with Delta>] - Percent RestoreFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of restorefh operations.
[-savefh-pct <Counter with Delta>] - Percent SaveFh Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of savefh operations.
[-secinf-pct <Counter with Delta>] - Percent SecInfo Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of secinfo operations.
[-sattr-pct <Counter with Delta>] - Percent SetAttr Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of setattr operations.
[-sclid-pct <Counter with Delta>] - Percent SetCliId Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of setcliid operations.
[-scidc-pct <Counter with Delta>] - Percent SetCliIdConf Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of setcliidconf operations.
[-verify-pct <Counter with Delta>] - Percent Verify Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of verify operations.
[-write-pct <Counter with Delta>] - Percent Write Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of write operations.
[-relown-pct <Counter with Delta>] - Percent RelLockOwn Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of rellockown operations.
The following example displays statistics about the NFSv4.1 operations for a node named node1:
cluster1::> statistics nfs show-v41 -node node1
Node                Value             Delta           Percent Ops   Delta
node1            ---------------------------success-----------------------
Null Procs:                  2             -              1%             -
Cmpnd Procs:                92             -                             -
Access Ops:                 16             -              6%             -
Close Ops:                   8             -              3%             -
Commit Ops:                  0             -              0%             -
Create Ops:                  0             -              0%             -
Delpur Ops:                  0             -              0%             -
Delrtn Ops:                  0             -              0%             -
Getattr Ops:                76             -             27%             -
Getfh Ops:                  22             -              8%             -
Link Ops:                    0             -              0%             -
Lock Ops:                    0             -              0%             -
Lockt Ops:                   0             -              0%             -
Locku Ops:                   0             -              0%             -
Lookup Ops:                 13             -              5%             -
Lookupp Ops:                 0             -              0%             -
Nverify Ops:                 0             -              0%             -
Open Ops:                    8             -              3%             -
Openattr Ops:                0             -              0%             -
Openconf Ops:                0             -              0%             -
Opendowng Ops:               0             -              0%             -
Putfh Ops:                  92             -             32%             -
Putpubfh Ops:                0             -              0%             -
Putrootfh Ops:               2             -              1%             -
Read Ops:                    0             -              0%             -
Readdir Ops:                 2             -              1%             -
Readlink Ops:                0             -              0%             -
Remove Ops:                  5             -              2%             -
Rename Ops:                  3             -              1%             -
Renew Ops:                   0             -              0%             -
Restorefh Ops:              11             -              4%             -
Savefh Ops:                 13             -              5%             -
Secinfo Ops:                 0             -              0%             -
Setattr Ops:                 8             -              3%             -
Setclid Ops:                 1             -              0%             -
Setclidconf Ops:             1             -              0%             -
Verify Ops:                  0             -              0%             -
Write Ops:                   3             -              1%             -
Rlockown Ops:                0             -              0%             -
Total Ops:                 286             -
node1            ---------------------------failure-----------------------
Null Procs:                  0             -              0%             -
Cmpnd Procs:                 0             -                             -
Access Ops:                  0             -              0%             -
Close Ops:                   0             -              0%             -
Getattr Ops:                 0             -              0%             -
Getfh Ops:                   0             -              0%             -
Link Ops:                    0             -              0%             -
Lock Ops:                    0             -              0%             -
Lockt Ops:                   0             -              0%             -
Locku Ops:                   0             -              0%             -
Lookup Ops:                  5             -             63%             -
Open Ops:                    2             -             25%             -
Putfh Ops:                   0             -              0%             -
Putrootfh Ops:               0             -              0%             -
Read Ops:                    0             -              0%             -
Readdir Ops:                 0             -              0%             -
Remove Ops:                  0             -              0%             -
Rename Ops:                  0             -              0%             -
Renew Ops:                   0             -              0%             -
Restorefh Ops:               0             -              0%             -
Savefh Ops:                  0             -              0%             -
Setattr Ops:                 1             -             13%             -
Setclid Ops:                 0             -              0%             -
Setclidconf Ops:             0             -              0%             -
Write Ops:                   0             -              0%             -
Total Ops:                   8             -
node1            ---------------------------  all  -----------------------
Cmpnd Procs:                92             -                             -
Access Ops:                 16             -              5%             -
Close Ops:                   8             -              3%             -
Getattr Ops:                76             -             26%             -
Getfh Ops:                  22             -              7%             -
Link Ops:                    0             -              0%             -
Lock Ops:                    0             -              0%             -
Lockt Ops:                   0             -              0%             -
Locku Ops:                   0             -              0%             -
Lookup Ops:                 18             -              6%             -
Open Ops:                   10             -              3%             -
Putfh Ops:                  92             -             31%             -
Read Ops:                    0             -              0%             -
Renew Ops:                   0             -              0%             -
Savefh Ops:                 13             -              4%             -
Setattr Ops:                 9             -              3%             -
Write Ops:                   3             -              1%             -
Total Ops:                 294             -
