statistics preset modify
Modify an existing Performance Preset
Modifies an existing performance preset configuration. The command modifies the global properties of a preset, but does not modify the details of the preset, such as specific objects and counters sampled.
-preset <text>- Preset Name (privilege: advanced)-
Name of the performance preset to be modified.
[-new-name <text>]- New Preset Name (privilege: advanced)-
Set preset name to the given new name.
[-comment <text>]- Preset Description (privilege: advanced)-
Set comment to the given value.
[-privilege <PrivilegeLevel>]- Preset Privilege Level (privilege: advanced)-
Set privilege level at which this preset can be viewed or modified to the given value. Possible values: admin, advanced, diagnostic.
cluster1::*> statistics preset show
Preset Name: delta
Preset UUID: 7a04f19d-02a7-11e2-8e40-123478563412
Comment: custom preset description
Privilege: diagnostic
Read-Only: false
Negative Preset: false
Application Order: 1
Archive Enabled: false
Generation ID: 0
1 entry was displayed.
cluster1::*> statistics preset modify -preset delta -comment "new comment"
Preset Name: delta
Comment: new comment
Read-Only: false
Generation ID: 0
