security key-manager external restore
Restore the key ID pairs from the key management servers.
This command retrieves and restores any current unrestored keys associated with the storage controller from the specified key management servers. When restoring keys from the external key manager associated with the admin Vserver, you must run the same command on the peer cluster. When restoring keys from a data Vserver, you can run the security key-manager external restore command on the active cluster only as the command is replicated on the peer cluster. This command is not supported when external key management has not been enabled for the Vserver. This command only restores keys from primary key servers.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
This parameter specifies the name of the node that will load unrestored key IDs into its internal key table. If not specified, all nodes retrieve unrestored keys into their internal key table.
 [-vserver <vserver name>]- Vserver Name-
This parameter specifies the Vserver for which to list the keys. If not specified, this command restores key for all Vservers.
 [-key-server <Hostname and Port>]- Key Server-
If this parameter is specified, this command restores keys from the key management server identified by the host and port. If not specified, this command restores keys from all available key management servers.
 [-key-id <Hex String>]- Key ID-
If you specify this parameter, then the command restores only the key IDs that match the specified value.
 [-key-tag <text>]- Key Tag-
If you specify this parameter, then the command restores only the key IDs that match the specified key-tag. The key-tag for Volume Encryption Keys (VEKs) is set to the UUID of the encrypted volume. If not specified, all key ID pairs for any key tags are restored.
The following command restores keys that are currently on a key server but are not stored within the key tables on the cluster. One key is missing for vserver clus- ter-1 on node1, and another key is missing for vserver datavs on node1 and node2:
cluster-1::> security key-manager external restore
Node: node1
            Vserver: cluster-1
         Key Server: 10.0.0.1:5696
Key ID
00000000000000000200000000000100a04fc7303d9abd1e0f00896192fa9c3f0000000000000000
Node: node1
            Vserver: datavs
         Key Server: tenant.keysever:5696
Key ID
00000000000000000200000000000400a05a7c294a7abc1e0911897132f49c380000000000000000
Node: node2
            Vserver: datavs
Key ID
