Command reference
storage failover progress-table show
Display status information about storage failover operations
The storage failover progress-table show displays status information about storage-failover operations. This information is organized in a resource table. The command displays the following information:
  • Node name
  • Resource-entry index number
  • Resource-entry name
  • Resource-entry state
  • Resource-entry failure code
  • Resource-entry time delta
This command is available only at the advanced privilege level and higher.
[-fields <fieldname>,…​]
If -fields <fieldname>, …​ is used, the command will only displays only the specified fields.
| [-instance ] (privilege: advanced) }
If this parameter is used, the command displays detailed information about all entries.
[-node {<nodename>|local}] - Node (privilege: advanced)
Selects the status information for the specified node.
[-index <integer>] - Resource Table Index (privilege: advanced)
Selects the status information for the specified index number.
[-entryname <text>] - Resource Table Entry Name (privilege: advanced)
Selects the status information for the specified entry name.
[-state <text>] - Resource Table Entry State (privilege: advanced)
Selects the status information for the specified state. Possible values include UP, START_RUNNING, START_DONE, START_FAILED, STOP_RUNNING, STOP_FAILED, TAKEOVER_BARRIER, and ONLY_WHEN_INITD.
[-failurecode <text>] - Entry Failure Code (privilege: advanced)
Selects the status information for the specified failure code. Possible values include OK, FAIL, FAIL_ALWAYS, HANG, PANIC, and VETO.
[-timedelta <integer>] - Entry Time Delta (privilege: advanced)
Selects the status information for the specified time delta.
The following example displays the entire storage-failover resource table:
cluster1::*> storage failover progress-table show
Node   Entry Name                             State       Time Delta
node0
       Pre-rsrctbl: fmdisk_resumePartnerDi    start_done            6
       Pre-rsrctbl: coredump_get_busy_spar    start_done          107
       Pre-rsrctbl: raid_preread_labels_be    start_done            1
       Pre-rsrctbl: fmdisk_reserve_all        start_done           84
       rsrctbl: fmrsrc_giveback_done          start_done            0
       rsrctbl: fmic                          start_done            0
       rsrctbl: fmdisk_reserve                start_done          171
       rsrctbl: fm_partnerSlowTimeout         start_done            1
       rsrctbl: fmdisk_inventory              start_done            0
       rsrctbl: fmfsm_reserve                 start_done            0
Press <space> to page down, <return> for next line, or 'q' to quit...
node0
       rsrctbl: rdb-ha                        start_done           36
       rsrctbl: giveback_cleanup_wait         start_done            0
       rsrctbl: priority_ha                   start_done            0
       rsrctbl: raid                          start_done          113
       rsrctbl: raid_disaster_early           start_done            0
       rsrctbl: wafl_nvram_replay             start_done            0
       rsrctbl: takeover_test_1               start_done            0
