storage failover progress-table show
Display status information about storage failover operations
The storage failover progress-table show displays status information about storage-failover operations. This information is organized in a resource table. The command displays the following information:
Node name
Resource-entry index number
Resource-entry name
Resource-entry state
Resource-entry failure code
Resource-entry time delta
This command is available only at the advanced privilege level and higher.
[-fields <fieldname>,…] -
If -fields <fieldname>, … is used, the command will only displays only the specified fields.
[-instance ]} -
If this parameter is used, the command displays detailed information about all entries.
[-node {<nodename>|local}]- Node (privilege: advanced)-
Selects the status information for the specified node.
[-index <integer>]- Resource Table Index (privilege: advanced)-
Selects the status information for the specified index number.
[-entryname <text>]- Resource Table Entry Name (privilege: advanced)-
Selects the status information for the specified entry name.
[-state <text>]- Resource Table Entry State (privilege: advanced)-
Selects the status information for the specified state. Possible values include UP, START_RUNNING, START_DONE, START_FAILED, STOP_RUNNING, STOP_FAILED, TAKEOVER_BARRIER, and ONLY_WHEN_INITD.
[-failurecode <text>]- Entry Failure Code (privilege: advanced)-
Selects the status information for the specified failure code. Possible values include OK, FAIL, FAIL_ALWAYS, HANG, PANIC, and VETO.
[-timedelta <integer>]- Entry Time Delta (privilege: advanced)-
Selects the status information for the specified time delta.
The following example displays the entire storage-failover resource table:
cluster1::*> storage failover progress-table show
Node Entry Name State Time Delta
node0
Pre-rsrctbl: fmdisk_resumePartnerDi start_done 6
Pre-rsrctbl: coredump_get_busy_spar start_done 107
Pre-rsrctbl: raid_preread_labels_be start_done 1
Pre-rsrctbl: fmdisk_reserve_all start_done 84
rsrctbl: fmrsrc_giveback_done start_done 0
rsrctbl: fmic start_done 0
rsrctbl: fmdisk_reserve start_done 171
rsrctbl: fm_partnerSlowTimeout start_done 1
rsrctbl: fmdisk_inventory start_done 0
rsrctbl: fmfsm_reserve start_done 0
Press <space> to page down, <return> for next line, or 'q' to quit...
node0
rsrctbl: rdb-ha start_done 36
rsrctbl: giveback_cleanup_wait start_done 0
rsrctbl: priority_ha start_done 0
rsrctbl: raid start_done 113
rsrctbl: raid_disaster_early start_done 0
rsrctbl: wafl_nvram_replay start_done 0
rsrctbl: takeover_test_1 start_done 0
