system node image package show
Display software package information
The package show command displays details of the software packages residing on the storage controller.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
Selects which node's packages are displayed. The local node is the default if this parameter is omitted.
[-package <text>]- Package File Name (privilege: advanced)-
This parameter specifies which package's information will be displayed.
cluster1::> system image package show
Package
Node Repository Package File Name
node-01
mroot
image.tgz
1 entries were displayed.
