storage failover check-takeover
Display status for all takeover options
The `storage failover check-takeover ` command displays information about whether takeover is possible based on verification checks triggered by the `-check-only ` parameter used with the storage failover takeover command.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Name of node command is run from
[-operation {takeover|giveback}]- Operation-
Failover Operation Type
[-option <takeover option>]- Takeover Option-
Takeover Option
[-operation-status {true|false}]- Operation Status-
Status of whether defined operation would succeed or not
[-reason <text>,…]- Reasons for Failure-
Reason for pre-takeover failure
The following is an example of the storage failover check-takeover command:
cluster1::*> storage failover check-takeover Node Operation Option Operation-Status Reasons for Failure -------------- ----------- ----------- ---------------- ------------------- Node 1 Takeover normal false Takeover request failed due to giveback in progress
