Command reference
qos settings cache modify
Modify the cache policy
The qos settings cache modify command modifies the existing default caching-policy. The list of caching policies can be obtained from the qos setting cache show -fields cache-setting command.
-cache-setting <text> - Cache Policy Name
Valid inputs to this parameter include any one of the listed caching-policies. This command is to be used together with the default parameter. If you use this parameter, the command modifies the specified caching-policy based on the default parameter.
[-default {true|false}] - Is Default?
Valid inputs to this parameter are true and false. Together with cache-setting, this parameter helps set or unset a caching-policy as default.
cluster1::> qos settings cache modify -default true -cache-setting random_read_write-random_write
Sets caching-policy random_read_write-random_write as default.
