Command reference
system health alert delete
Delete system health alert
The system health alert delete command deletes all the alerts on the cluster with the specified input parameters.
-node {<nodename>|local} - Node
Use this parameter to delete alerts generated on a cluster only on the node you specify.
-monitor <hm_type> - Monitor
Use this parameter to delete alerts generated on a cluster only on the monitor you specify.
-alert-id <text> - Alert ID
Use this parameter to delete alerts generated on a cluster only on the alert ID you specify.
-alerting-resource <text> - Alerting Resource
Use this parameter to delete alerts generated on a cluster on the alerting resource you specify.
This example shows how to delete an alert with the specified alert-id:
cluster1::> system health alert delete -alert-id DualPathToDiskShelf_Alert -alerting-resource *
