Command reference
volume file clone deletion add-extension
Add new supported file extensions to be deleted with clone delete
The volume file clone deletion add-extension command can be used to add new supported file extensions for clone delete.
-vserver <vserver name> - Vserver Name
Name of the vserver.
-volume <volume name> - Volume Name
Name of the volume.
-extensions <text> - Supported Extensions for Clone Delete
List of supported file extensions for clone delete.
The following example adds the new supported vmdk,vhd file extensions to volume vol1 of vserver vs1 .
cluster1::> volume file clone deletion add-extension -vserver vs1 -volume vol1 -extensions vmdk,vhd
