Command reference
vserver iscsi interface accesslist remove
Remove the iSCSI LIFs from the accesslist of the specified initiator
This command removes network interfaces from an access list for a specified initiator. The system removes the access list when the list is empty. When you remove a network interface from an initiator, this action could result in the shutdown of active sessions.
-vserver <Vserver Name> - Vserver
Specifies the Vserver name.
-initiator-name <text> - Initiator Name
Specifies the initiator that you want to remove logical interfaces from.
{ -lif <lif-name>,…​ - Logical Interface
Specifies the logical interface you want to remove.
| -a, -all <true> - All }
If you use this parameter without a value, it is set to true, and the command removes all of the iSCSI data logical interfaces from an initiator's accesslist. If you remove all the network interfaces from an access list, the system removes the access list.
[-f, -force <true>] - Force
If you use this parameter without a value, it is set to true, and the command does not prompt you when an active iSCSI service or any active iSCSI data logical interfaces could be affected. If you do not use this parameter, the command prompts for confirmation if the iSCSI service is active or if any active data logical interfaces would be affected.
cluster1::> vserver iscsi interface accesslist remove -vserver vs_1 -initiator-name iqn.1992-08.com.example:abcdefg -a
Removes all the network interfaces from the access list for initiator iqn.1992-08.com.example:abcdefg on Vserver vs_1.
