Command reference
metrocluster configuration-settings calibration show
Display the calibration measurements for local nodes in MetroCluster over IP configuration
The metrocluster configuration-settings calibration show command shows the bandwidth and latency between local and remote nodes in a MetroCluster over IP configuration.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-calibration-id <integer>] - Calibration ID
This field specifies Calibration ID.
[-subnet <IP Address>] - IP Subnet
This field specifies subnet.
[-node-uuid <UUID>] - Node UUID
This field specifies UUID of the node.
[-home-port {<netport>|<ifgrp>}] - Home Port
This field specifies name of the port used to measure latency and bandwidth.
[-node {<nodename>|local}] - Node Name
This field specifies name of the node.
[-collection-time <MM/DD/YYYY HH:MM:SS>] - Collection Time of Sample
This field specifies collection time of sample.
[-source-address <IP Address>] - Source Network Address
This field specifies IP address of the port on the node.
[-destination-address <IP Address>] - Destination Network Address
This field specifies IP address of the port on the partner node.
[-latency <double>] - Latency in ms
This field specifies latency in ms.
[-bandwidth <double>] - Bandwidth in Mb/s
This field specifies bandwidth in Mb/s.
[-num-packets-retransmitted <integer>] - Number of Packets Retransmitted
This field specifies the number of TCP packets retransmitted during bandwidth measurement.
[-pct-pkt-retrans <double>] - Percentage of packages retransmitted
This field specifies the percent of TCP packets retransmitted during bandwidth measurement.
The following example shows the output for the calibration show command in MetroCluster over IP configurations:
clusA::*> metrocluster configuration-settings calibration show
                                   Home Latency Bandwidth
  ID Subnet         Node     Port (ms)    (Mb/s)    Collection Time
  1  172.21.96.0    A1
                                   e0f  0.341   764       8/6/2019 16:20:07
                                   e0g  0.311   629       8/6/2019 16:20:22
        A2
                                   e0f  0.307   1265      8/6/2019 16:20:36
                                   e0g  0.307   1063      8/6/2019 16:20:50
  4 entries were displayed.
