metrocluster configuration-settings calibration show
Display the calibration measurements for local nodes in MetroCluster over IP configuration
The metrocluster configuration-settings calibration show command shows the bandwidth and latency between local and remote nodes in a MetroCluster over IP configuration.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-calibration-id <integer>]- Calibration ID-
This field specifies Calibration ID.
[-subnet <IP Address>]- IP Subnet-
This field specifies subnet.
[-node-uuid <UUID>]- Node UUID-
This field specifies UUID of the node.
[-home-port {<netport>|<ifgrp>}]- Home Port-
This field specifies name of the port used to measure latency and bandwidth.
[-node {<nodename>|local}]- Node Name-
This field specifies name of the node.
[-collection-time <MM/DD/YYYY HH:MM:SS>]- Collection Time of Sample-
This field specifies collection time of sample.
[-source-address <IP Address>]- Source Network Address-
This field specifies IP address of the port on the node.
[-destination-address <IP Address>]- Destination Network Address-
This field specifies IP address of the port on the partner node.
[-latency <double>]- Latency in ms-
This field specifies latency in ms.
[-bandwidth <double>]- Bandwidth in Mb/s-
This field specifies bandwidth in Mb/s.
The following example shows the output for the calibration show command in MetroCluster over IP configurations:
clusA::*> metrocluster configuration-settings calibration show
Home Latency Bandwidth
ID Subnet Node Port (ms) (Mb/s) Collection Time
1 172.21.96.0 A1
e0f 0.341 764 8/6/2019 16:20:07
e0g 0.311 629 8/6/2019 16:20:22
A2
e0f 0.307 1265 8/6/2019 16:20:36
e0g 0.307 1063 8/6/2019 16:20:50
4 entries were displayed.
