vserver create
Create a Vserver
The vserver create command creates a Vserver.
-vserver <vserver>- Vserver-
This specifies the name of the Vserver that is to be created. Use a fully qualified domain name (FQDN) - for example, "data.example.com" - for the Vserver to ensure unique Vserver names across cluster leagues.
Maximum number of characters supported is 47, and 41 for a Vserver with subtype "sync-source". "all" is a reserved name and must not be used as a Vserver name. [-subtype <vserver subtype>]- Vserver Subtype-
This specifies the subtype of the Vserver being created. Possible values are:
default - For default data Vservers
dp-destination - For Data Protection destination Vservers
sync-source - For MetroCluster source Vservers
sync-destination - For MetroCluster destination Vservers
data-engine - For Data Engine Vservers
[-rootvolume <volume name>]- Root Volume-
This parameter optionally specifies the name of the Vserver's root volume, which is created when the Vserver is created. The default name is
vserverName_root. The size of the Vserver's root volume is 1GB [-aggregate <aggregate name>]- Aggregate-
This parameter optionally specifies the storage aggregate that holds the Vserver's root volume. Selection of the aggregate is based on the Vserver setup algorithm.
Creating a root volume on the SnapLock aggregate is not supported.
Creating a root volume of sync-source Vserver on the unmirrored aggregate is not supported.
[-rootvolume-security-style <security style>]- Root Volume Security Style-
This parameter optionally specifies the security style for the Vserver's root volume. Possible values include
unix(for UNIX mode bits),ntfs(for CIFS ACLs), andmixed(for mixed NFS and CIFS access). The default value isunix. Regardless of the security style, both NFS and CIFS clients can read from and write to the root volume. [-language <Language code>]- Default Volume Language Code-
This optionally specifies the default language encoding setting for the Vserver and its volumes. The recommended format is to append
.UTF-8for the language encoding values. For example, for theen_USlanguage, the recommended format isen_US.UTF-8. The default setting isC.UTF-8. [-snapshot-policy <snapshot policy>]- Snapshot Policy-
This optionally specifies the snapshot policy for new volumes created on the Vserver. If no value is specified, the default snapshot policy is used. You can use the
-snapshot-policyparameter on the volume create or volume modify commands to set the snapshot policy on a specific volume, regardless of its Vserver's snapshot policy setting. [-data-services <LIF Service Name>,…]- Data Services-
This optionally specifies the data services for new network interfaces created on the Vserver. If no value is specified, the default services list will be applied. This information will be used to construct the default service policies for this Vserver, which can be viewed using the
network interface service-policy showcommand. [-comment <text>]- Comment-
This optionally specifies a comment for the Vserver.
[-quota-policy <text>]- Quota Policy-
This optionally specifies a quota policy for the Vserver.
[-caching-policy <text>]- Caching Policy Name-
This optionally specifies the caching policy to apply to the Vserver. A caching policy defines how the system caches this volume's data in Flash Cache modules. If a caching policy is not assigned to this Vserver, the system uses the default cluster-wide policy. The available caching policies are:
none - Does not cache any user data or metadata blocks.
auto - Read caches all metadata and randomly read user data blocks, and write caches all randomly overwritten user data blocks.
meta - Read caches only metadata blocks.
random_read - Read caches all metadata and randomly read user data blocks.
random_read_write - Read caches all metadata, randomly read and randomly written user data blocks.
all_read - Read caches all metadata, randomly read, and sequentially read user data blocks.
all_read_random_write - Read caches all metadata, randomly read, sequentially read, and randomly written user data.
all - Read caches all data blocks read and written. It does not do any write caching.
Default caching-policy is auto.
[-ipspace <IPspace>]- IPspace Name-
This optionally specifies the IPspace the Vserver will be assigned to. If left unspecified, the Vserver will be assigned to the default IPspace.
[-foreground {true|false}]- Foreground Process-
This parameter optionally specifies whether the Vserver create operation can be executed in the background. If nothing is specified, by default the Vserver create operation is executed in the foreground.
[-is-space-reporting-logical {true|false}]- Logical Space Reporting-
This optionally specifies whether to report space logically on residing volumes. When space is reported logically, ONTAP reports the volume space such that all the physical space saved by the storage efficiency features are also reported as used.
[-is-space-enforcement-logical {true|false}]- Logical Space Enforcement-
This optionally specifies whether to perform logical space accounting on residing volumes. When space is enforced logically, ONTAP enforces volume settings such that all the physical space saved by the storage efficiency features will be calculated as used.
[-anti-ransomware-default-volume-state {disabled|dry-run}]- Default Anti_ransomware State of the Vserver's Volumes-
This optionally specifies the default anti_ransomware state for volumes in the Vserver. The available anti_ransomware states for the volumes in the Vserver are:
disabled - Anti_ransomware protection is not enabled on the volumes in the Vserver.
dry-run - Anti_ransomware protection is in learning mode on the volumes in the Vserver. This state is deprecated and may be removed in a future release.
Default anti-ransomware-default-volume-state is
disabled. -
[-auto-enable-analytics {true|false}]- Enable Analytics on New Volumes-
This parameter specifies whether analytics is automatically enabled on volumes that will be created in the Vserver.
If a value is specified by the user during Vserver creation:
Setting this parameter to
trueexplicitly enables automatic analytics enablement for new volumes in this Vserver. -
falseexplicitly disables automatic analytics enablement for new volumes in this Vserver. -
If this parameter is not specified during Vserver creation, the effective setting is determined by the cluster-level configuration managed by the
volume analytics cluster-configcommand. The cluster configuration has three states for "Is Enabled by Default": -
true: If the cluster-config is set totrue, then-auto-enable-analyticsdefaults totrue. -
false: If the cluster-config is set tofalse, then-auto-enable-analyticsdefaults tofalse. -
-(unset): If the cluster-config is unset, then-auto-enable-analyticsdefaults tofalse.
[-auto-enable-activity-tracking {true|false}]- Enable Activity Tracking on New Volumes-
This parameter specifies whether activity tracking is automatically enabled on volumes that will be created in the Vserver. The default value is false.
[-storage-limit {<integer>[KB|MB|GB|TB|PB]}]- Storage Limit-
This parameter specifies the maximum size limit for a Vserver. Default value is 0, which means no limit.
[-storage-limit-threshold-alert <percent>]- Storage Limit Threshold Alert-
This parameter specifies when the "vserver.storage.threshold" event log message is generated. This is a percentage value of storage-limit. Default value is 90%.
[-qos-adaptive-policy-group-template <text>]- QoS Adaptive Policy Group Template-
This optionally specifies which QoS adaptive policy group to apply to the Vserver as a template. This policy group will then be assigned to volumes created or moved into this Vserver, if they do not already have a policy group assigned to them. This policy group defines measurable service level objectives (SLOs) and Service Level Agreements (SLAs) that adjust based on the volume allocated space or used space.
[-anti-ransomware-auto-switch-from-learning-to-enabled {true|false}]- (DEPRECATED) Anti-ransomware Auto-switch from Learning to Enabled-
This parameter optionally specifies whether anti-ransomware state of the volumes in this Vserver are automatically switched by the system from "learning" (dry-run) to "enabled" (active) state after sufficient learning. The default value is
true. This parameter is deprecated and may be removed in a future release. [-anti-ransomware-auto-switch-minimum-incoming-data-percent <percent>]- (DEPRECATED) Anti-ransomware Auto-switch Minimum Incoming Data (in percentage)-
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this Vserver from “learning” (dry-run) to “enabled” is that the volume should have sufficient data ingested to do the learning. This parameter optionally specifies the minimum amount of data (in percentage) to be written to a given volume during the learning period to automatically switch the anti-ransomware state from “learning” to “enabled”. The amount of data considered as ingested also includes the data that is deleted or overwritten after ingestion. The default value is 5%. This parameter is deprecated and may be removed in a future release.
[-anti-ransomware-auto-switch-duration-without-new-file-extension <integer>]- (DEPRECATED) Anti-ransomware Auto-switch Duration Without New File Extension (in Days)-
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this Vserver from “learning” (dry-run) to “enabled” is that no new file-extensions are observed in the volume in recent time. This parameter optionally specifies the recent time duration (in days) to be considered during which no new file-extension should be observed in a given volume to automatically switch the anti-ransomware state from ‘learning” to “enabled”. The default value is
3days. This parameter is deprecated and may be removed in a future release. [-anti-ransomware-auto-switch-minimum-learning-period <integer>]- (DEPRECATED) Anti-ransomware Auto-switch Minimum Learning Period-
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this Vserver from “learning” (dry-run) to “enabled” is that the volume should be in “learning” state for sufficient time period. This parameter optionally specifies the minimum number of days a given volume should be in “learning” state to automatically switch the anti-ransomware state from “learning” to “enabled”. The default value is
10days. This parameter is deprecated and may be removed in a future release. [-anti-ransomware-auto-switch-minimum-file-count <integer>]- (DEPRECATED) Anti-ransomware Auto-switch Minimum File Count-
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this Vserver from “learning” (dry-run) to “enabled” is that the volume should have sufficient number of files created in “learning” state. This parameter optionally specifies the minimum number of new files to be created in a given volume in “learning” state to automatically switch the anti-ransomware state from “learning” to “enabled”. The default value is
200. This parameter is deprecated and may be removed in a future release. [-anti-ransomware-auto-switch-minimum-file-extension <integer>]- (DEPRECATED) Anti-ransomware Auto-switch Minimum File Extension-
One of the many conditions to be satisfied to automatically switch the anti-ransomware state of the volumes in this Vserver from “learning” (dry-run) to “enabled” is that the volume should have sufficient unique file extension count in “learning” state. This parameter optionally specifies the minimum number of unique file extension count in a given volume in “learning” state to automatically switch the anti-ransomware state from “learning” to “enabled”. The default value is
10days. This parameter is deprecated and may be removed in a future release. [-san-multipathing {local-active|active-active|active-active-scsi-only}]- SAN Multipathing-
This parameter specifies the multipathing mode for SAN and NVMe protocols supported by the Vserver. Possible values are:
local-active - Only node-local paths are active/optimized.
active-active - All paths in the HA pair are active/optimized.
active-active-scsi-only - This value is available only on the original edition of ONTAP All SAN Array (ASA r1). This value provides the active-active behavior, but only for the iSCSI and FCP protocols.
The following example creates a Vserver named vs0.example.com in the IPspace ipspace123. The Vserver's root volume is named root_vs0 and is located on aggregate aggr0 . The Vserver uses NIS for network information, a file for name mapping information, and the language is U.S. English:
cluster1::> vserver create -vserver vs0.example.com -ipspace ipspace123 -rootvolume root_vs0 -aggregate aggr0 -language en_US.UTF-8 -rootvolume-security-style mixed
The following example creates a Vserver named vs1 using default values. The default name for the Vserver's root volume is vserverName_root and the Vserver is located on an aggregate selected on the basis of the Vserver setup algorithm. The default root volume's security style is set to unix .
cluster1::> vserver create -vserver vs1
cluster1::> vserver show -vserver vs1 -fields rootvolume, rootvolume-security-style, aggregate
vserver rootvolume aggregate rootvolume-security-style
vs1 vs1_root aggr1 unix
