Command reference
vserver object-store-server group create
Create an Object Store Server Group
The vserver object-store-server group create command creates an object store group.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the name of the Vserver on which to create the object store group. The Vserver must already exist.
-gid <integer> - Group ID
This parameter specifies a unique ID used to identify a particular object store group.
-name <TextNoCase> - Group Name
This parameter specifies the name of the object store group.
[-users <TextNoCase>,…​] - List of Users Belonging to the Group
Use this parameter to specify the list of object store users who belong to the object store group.
[-policies <TextNoCase>,…​] - List of Policies Attached to the Group
Use this parameter to specify the list of object store policies that are attached to the object store group.
[-comment <text>] - Group Description
This optional parameter specifies a text comment for the object store group.
The following example creates an object store group named user_group for Vserver vs1:
cluster1::> vserver object-store-server group create -vserver vs1 -name user_group -users user1,user2 -policies policy1,policy2 -comment "UserGroup1"
