Command reference
security session limit vserver show
Show per-vserver session limits
This command shows the per-Vserver management session limits that have been configured for each interface and Vserver.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-interface {cli|ontapi|rest}] - Interface (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) to which the limit applies.
[-vserver <vserver>] - Vserver (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the Vserver for the limit. The "Cluster" Vserver is used to limit Vservers that do not have a configured limit.
[-max-active-limit <integer>] - Max-Active Limit (privilege: advanced)
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the per-Vserver limits for management sessions.
cluster1::*> security session limit vserver show
Interface Vserver              Max-Active
cli       Cluster                       4
ontapi    Cluster                       2
ontapi    cluster1                     16
3 entries were displayed.
