Command reference
system controller platform-capability show
Display platform capabilities
The system controller platform-capability show command displays information about all platform capabilities for each controller in the cluster. By default, the command displays the following information about all controllers in the cluster:
  • Controller Name
  • Capability ID
  • Capability Supported?
  • Capability Name
{ [-fields <fieldname>,…​]
| [-instance ] }
Displays detailed information about all controllers in the cluster.
[-node {<nodename>|local}] - Node
Selects information about the specified controller.
[-capability-id <integer>] - Capability ID
Selects the desired capability ID.
[-supported <text>] - Supported?
Selects the desired capability support state (true or false).
[-name <text>] - Capability Name
Selects the desired capability name.
The following example displays platform capability information for the controller:
cluster1::> system controller platform-capability show
      Node             Capability ID Supported? Capability Name
      or-099-diag-01
                       0             false      CAP_CMCI_ENABLED
                       1             false      CAP_HA_CONFIG_ONLY
                       2             true       CAP_SUPPORT_CARD_FRU
                       3             true       CAP_SCORPIO_EN
                       4             false      CAP_NVD_EN
                       5             false      CAP_ENABLE_HPET
                       6             false      CAP_VERIFY_ACPI_TABLE
      7 entries were displayed.
