Command reference
vserver iscsi isns stop
Stops the iSNS service
Stops the iSNS service. Once you stop the iSNS service, the Vserver loses the ability to register with the iSNS server and to be discovered by iSNS clients.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver for the iSNS service that you want to stop.
cluster1::> vserver iscsi isns stop -vserver vs_1
Stops the iSNS service for Vserver vs_1.
