The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver iscsi isns stop
PDF of this doc site
Creating your file...
Your file is ready
Stops the iSNS service
Stops the iSNS service. Once you stop the iSNS service, the Vserver loses the ability to register with the iSNS server and to be discovered by iSNS clients.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver for the iSNS service that you want to stop.
cluster1::> vserver iscsi isns stop -vserver vs_1
Stops the iSNS service for Vserver vs_1.
