Command reference
security anti-ransomware volume event-log modify
Modify anti-ransomware event-log for volumes
The security anti-ransomware volume event-log command.
-vserver <vserver name> - Vserver Name
This parameter specifies the Vserver of anti-ransomware enabled volume.
-volume <volume name> - Volume Name
This parameter specifies the anti-ransomware enabled volume.
[-is-enabled-on-new-file-extension-seen {true|false}] - Is Enabled on New File Extension Seen
This parameter indicates whether an alert event should be created when files with new extensions are created.
[-is-enabled-on-snapshot-copy-creation {true|false}] - Is Enabled on Snapshot Copy Creation
This parameter indicates whether an alert event should be created when snapshots are created.
cluster1::> security anti-ransomware volume event-log modify -vserver vs1 -volume vol1 -is-enabled-on-new-file-extension-seen true -is-enabled-on-snapshot-copy-creation true
cluster1::> security anti-ransomware volume event-log show -vserver vs1 -volume vol1
Vserver : vs1
                    Volume : vol1
            Is Enabled on
   New File Extension Seen : true
            Is Enabled on
    Snapshot Copy Creation : true
