Command reference
system node coredump save
Save an unsaved kernel coredump
The system node coredump save command saves a specified core dump. If the node has already attempted to save the core dump by the value specified by the -save-attempts parameter, the command prompts you before continuing. The -save-attempts parameter is set by invoking the command system node coredump config modify . A saved core dump can be uploaded to a remote site for support analysis; see the system node coredump upload command man page for more information.
-node {<nodename>|local} - Node That Owns the Coredump
This specifies the node on which the core dump is located.
-corename <text> - Coredump Name
This specifies the core dump that is to be saved.
The following example saves a core dump named core.101268397.2010-05-30.19_37_31.nz on a node named node0:
cluster1::> system node coredump save -node node0 -corename core.101268397.2010-05-30.19_37_31.nz
