Command reference
network bgp vserver-status show
Display Vserver BGP status
The network bgp vserver-status show command displays the per-node border gateway protocol (BGP) status for each vserver. The BGP status for a particular vserver is "up" when at least one BGP peer group supporting that vserver is able to communicate with its peer router.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
This parameter selects the BGP status that match the specified node.
[-vserver <vserver name>] - Vserver
This parameter selects the BGP status for specified vserver.
[-ipv4-status {unknown|unconfigured|up|down}] - IPv4 status
This parameter selects the BGP status that matches the specified status for IPv4 address family.
[-ipv6-status {unknown|unconfigured|up|down}] - IPv6 status
This parameter selects the BGP status that matches the specified status for IPv6 address family.
cluster1::> network bgp vserver-status show
    Node                vserver    IPv4 status IPv6 status
    node1               vs1        up          up
