network bgp vserver-status show
Display Vserver BGP status
The network bgp vserver-status show
command displays the per-node border gateway protocol (BGP) status for each vserver. The BGP status for a particular vserver is "up" when at least one BGP peer group supporting that vserver is able to communicate with its peer router.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
This parameter selects the BGP status that match the specified node.
[-vserver <vserver name>]
- Vserver-
This parameter selects the BGP status for specified vserver.
[-ipv4-status {unknown|unconfigured|up|down}]
- IPv4 status-
This parameter selects the BGP status that matches the specified status for IPv4 address family.
[-ipv6-status {unknown|unconfigured|up|down}]
- IPv6 status-
This parameter selects the BGP status that matches the specified status for IPv6 address family.
cluster1::> network bgp vserver-status show Node vserver IPv4 status IPv6 status ------------------- ---------- ----------- ----------- node1 vs1 up up
