Command reference
volume quota policy show
Display the quota policies
This command displays information about quota policies. The command displays the following information about all quota policies:
  • Vserver name
  • Policy name
  • When the policy was last modified
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays information about the quota policies for the specified Vserver.
[-policy-name <text>] - Policy Name
If this optional parameter is specified, the command displays information about quota policies that match the specified name.
[-last-modified <MM/DD/YYYY HH:MM:SS>] - Last Modified
If this optional parameter is specified, the command displays information about quota policies with the last modified time that match the given time.
The following example displays information about all quota policies.
cluster1::> volume quota policy show
Vserver            Policy  Name           Last Modified
vs0                quota_policy_vs0       10/16/2008 17:40:05
vs1                quota_policy_vs1       10/16/2008 17:47:45
vs2                quota_policy_vs2       10/16/2008 17:44:13
vs3                quota_policy_vs3       10/16/2008 17:44:13
4 entries were displayed.
