Command reference
vserver nvme subsystem host remove
Remove a host from a subsystem
The vserver nvme subsystem host remove command removes an NVMe host from an NVMe subsystem on a Vserver.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-subsystem <text> - Subsystem
Specifies the NVMe target subsystem.
-host-nqn <text> - Host NQN
Specifies the NVMe subsystem host NQN.
cluster::*> vserver nvme subsystem host remove -vserver vs_1 -subsystem sub_1 -host-nqn nqn.2001-01.com.example:host1
Removes the host with the specified NQN from NVMe subsystem sub_1 on Vserver vs_1 .
