security dynamic-authorization executed-commands show
Display executed commands
The security dynamic-authorization executed-commands show command displays information about the executed commands according to the dynamic authorization rules.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays all the fields for the dynamic authorization executed commands.
[-vserver <vserver name>]- Vserver-
Selects the dynamic authorization executed command fields that match this Vserver.
[-date <MM/DD/YYYY HH:MM:SS>]- Date-
Selects the dynamic authorization executed command fields that match this date.
[-username <text>]- Username-
Selects the dynamic authorization executed command fields that match this username.
[-operation <text>]- Operation-
Selects the dynamic authorization executed command fields that match this operation.
[-count <integer>]- Count-
Selects the dynamic authorization executed command fields that match this count.
[-score <integer>]- Trust Score-
Selects the dynamic authorization executed command fields that match this score.
[-result {permit|deny|challenge}]- Result-
Selects the dynamic authorization executed command fields that match this result.
The example below displays information about all dynamic authorization executed commands:
cluster1::> security dynamic-authorization executed-commands show
Vserver: usernamecluster-1
Date Operation Username Count Trust Score Result
12/7/2023 08:25:57 security login create
admin 1 100 permit
12/7/2023 08:26:04 security login unlock
admin 1 100 permit
12/7/2023 08:26:09 security multi-admin-verify approval-group create
admin 1 100 permit
3 entries were displayed.
