Command reference
storage shelf port show
Display storage shelf ports
The storage shelf port show command displays information for storage shelf ports in the storage system. If no parameters are specified, the default command displays the following information for the ports:
  • Shelf Name
  • ID
  • Module
  • State
  • Internal?
To display detailed information for a single port, use the -shelf and -id parameters.
{ [-fields <fieldname>,…​]
Displays output in column style about the specified fields for all shelf ports.
| [-cables ]
Displays information about all cables connected to the shelf ports.
| [-instance ]
Displays expanded information for all shelf ports in the system. If a shelf and ID are specified, then this parameter displays the same detailed information for the specified port as does the -shelf and -id parameters.
[-shelf <text>] - Shelf Name
Displays the ports in the storage shelf that matches the specified shelf name.
[-id <integer>] - Port ID
Displays the ports that match the specified ID.
[-node {<nodename>|local}] - Node Name
Displays the ports that are present for the specified node.
[-module-id {A|B}] - Module ID
Displays the ports from the specified shelf module ID.
[-is-internal {true|false}] - Is Port Internal?
Displays the ports that are internal.
[-location <text>] - Location
Displays the ports with the specified location.
[-is-cable-connected {true|false}] - Is Cable Connected?
Displays the ports that have cables connected to them.
[-is-error {true|false}] - Any Errors?
Displays the ports for which errors have been logged.
[-connector-state {connected|disconnected|error}] - Connector State
Displays the ports with the specified connector state.
[-connector-serial-number <text>] - Connector Serial Number
Displays the ports with the specified connector serial number.
[-connector-type {QSFP|QSFP+|QSFP28|Mini-SAS-HD}] - Connector Type
Displays the ports with the specified connector type.
[-cable-vendor <text>] - Cable Vendor
Displays the ports that are connected to a cable from the specified vendor.
[-cable-part-number <text>] - Cable Part Number
Displays the ports that are connected to a cable with the specified part number.
[-cable-technology {active-copper|passive-copper|optical}] - Cable Technology
Displays the ports that are connected to a cable with the specified technology.
[-cable-length <text>] - Cable Length
Displays the ports that are connected to a cable with the specified length.
[-cable-id <text>] - Cable ID
Displays the ports that are connected to a cable with the specified ID.
[-cable-end {end_0|end_1}] - Cable End
Displays the ports that are connected to a cable with the specified cable end.
[-designator <text>] - Designator
Displays the ports with the specified designator.
[-wwn <text>] - Local Device WWN
Displays the ports with the specified WorldWide Name (WWN).
[-remote-wwn <text>] - Remote Device WWN
Displays the ports connected to the specified remote WorldWide Name (WWN).
[-remote-phy <text>] - Remote Phy
Displays the ports connected to the specified remote PHY.
[-swap-count <integer>] - Swap Count
Displays the ports with the specified swap count.
[-mac <MAC Address>] - Local MAC Address
Displays the ports with the specified MAC address.
[-remote-mac <MAC Address>] - Remote MAC Address
Displays the ports connected to the specified MAC address.
[-remote-port <text>] - Remote Port
Displays the ports connected to the specified port.
[-remote-chassis <text>] - Remote Chassis
Displays the ports connected to the specified chassis.
[-remote-device <text>] - Remote Device
Displays the ports connected to the specified device.
[-vlan-id <integer>] - VLAN ID
Displays the ports with the specified Virtual LAN (VLAN) ID.
[-link-state {unknown|online|offline}] - Link State
Displays the ports with the specified link state.
[-speed <integer>] - Speed
Displays the ports in the storage shelf with the specified Ethernet port speed.
The following example displays information about all shelf ports:
cluster1::> storage shelf port show
Shelf ID Module State        Internal?
1.4
       0 A      connected    false
       1 A      connected    false
       2 B      connected    false
       3 B      connected    false
4 entries were displayed.
The following example displays expanded information about port 0 in shelf 1.4:
cluster1::> storage shelf port show -shelf 1.4 -id 0
Shelf Name: 1.4
                Port ID: 0
              Module ID: A
      Is Port Internal?: false
               Location: rear of the shelf at the top left, on shelf module A
    Is Cable Connected?: true
            Any Errors?: false
        Connector State: connected
Connector Serial Number: 616930439
         Connector Type: qsfp+
           Cable Vendor: Molex Inc.
      Cable Part Number: 112-00431+A0
       Cable Technology: passive-copper
           Cable Length: 5m
               Cable ID: 500a0980000b6c3f-50000d1703544b80
              Cable End: end_1
             Designator: sqr
       Local Device WWN: 500A0980000B6C3F
      Remote Device WWN: 50000D1703544B80
             Remote Phy: 12
             Swap Count: 0
The following example displays information about the cables:
cluster1::> storage shelf port show -cables
Shelf: 1.4
ID Vendor     Part Number   Technology     Length   Type        Serial Number
 0 Molex Inc. 112-00431+A0  passive-copper 5m       qsfp+       616930439
 1 Molex Inc. 112-00431+A0  passive-copper 5m       qsfp+       616930364
 2 Molex Inc. 112-00431+A0  passive-copper 5m       qsfp+       616930452
 3 Molex Inc. 112-00431+A0  passive-copper 5m       qsfp+       616930474
