cluster image validate
Validates the cluster's update eligibility
The cluster image validate command checks for issues within the cluster that might lead to problems during the update.
- [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- [-version <text>]- Update Version
Specifies the ONTAP version to use to validate the cluster.
- [-rolling <true>]- Rolling Update
Specify this optional parameter on a cluster with eight or more nodes to perform a rolling-update check. The default is to perform a batch-update check. This parameter is only supported on a cluster with eight or more nodes, and is not supported for two-node MetroCluster.
- [-nodes {<nodename>|local}]- Nodes
Specifies the nodes that are to be validated. This parameter is not supported for MetroCluster configurations and for two-stage upgrades.
- [-show-validation-details <true>]- Shows All Validation Details
Specify to display all validation details. Default: do not display all details.
- [-skip-nodes-at-target-version <true>]- Skip Nodes at Target Version (privilege: advanced)
Specifies that the validation will skip the nodes which are already running target version. Default: true.
The following example shows the validate operation:
cluster1::> cluster image validate -version 9.16.1 It can take several minutes to complete validation... WARNING: There are additional manual upgrade validation checks that must be performed after these automated validation checks have completed successfully. Refer to the Upgrade Advisor Plan or the "What should I verify before I upgrade with or without Upgrade Advisor" section in the "Upgrade ONTAP" documentation for the remaining manual validation checks that need to be performed before update. Upgrade ONTAP documentation available at: https://docs.netapp.com/us-en/ontap/upgrade/index.html The list of checks are available at: https://docs.netapp.com/us-en/ontap/upgrade/task_what_to_check_before_upgrade.html Failing to do so can result in an update failure or an I/O disruption. Please use Interoperability Matrix Tool (IMT http://mysupport.netapp.com/matrix) to verify host system supportability configuration information. Validation checks started. Run the "cluster image show-update-progress" command to check validation status.
The following example shows the validate operation with validation details:
cluster1::> cluster image validate -version 9.16.1 -show-validation-details It can take several minutes to complete validation... WARNING: There are additional manual upgrade validation checks that must be performed after these automated validation checks have completed successfully. Refer to the Upgrade Advisor Plan or the "What should I verify before I upgrade with or without Upgrade Advisor" section in the "Upgrade ONTAP" documentation for the remaining manual validation checks that need to be performed before update. Upgrade ONTAP documentation available at: https://docs.netapp.com/us-en/ontap/upgrade/index.html The list of checks are available at: https://docs.netapp.com/us-en/ontap/upgrade/task_what_to_check_before_upgrade.html Failing to do so can result in an update failure or an I/O disruption. Please use Interoperability Matrix Tool (IMT http://mysupport.netapp.com/matrix) to verify host system supportability configuration information. Validation checks started. Run the "cluster image show-update-progress" command to check validation status.
 PDFs
PDFs
