cluster image validate
Validates the cluster's update eligibility
The cluster image validate command checks for issues within the cluster that might lead to problems during the update.
[-fields <fieldname>,…]-
If you specify the
-fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. [-version <text>]- Update Version-
Specifies the Data ONTAP version to use to validate the cluster.
[-rolling <true>]- Rolling Update-
Specify this optional parameter on a cluster with eight or more nodes to perform a rolling-update check. The default is to perform a batch-update check.
This parameter is only supported on a cluster with eight or more nodes, and is not supported for two-node MetroCluster. [-nodes {<nodename>|local}]- Nodes-
Specifies the nodes that are to be validated. This parameter is not supported for MetroCluster configurations and for two-stage upgrades.
The following example shows the validate operation:
cluster1::> cluster image validate -version 8.3 It can take several minutes to complete validation... Pre-update Check Status Error-Action --------------------- --------- ------------------------------------------- CIFS status OK Cluster health status OK Clsuter quorum status OK Disk status OK High Availability OK status LIF status OK LIFs on home node OK MetroCluster OK configuration status SnapMirror status OK Overall Status OK 10 entries were displayed.
