ONTAP commands
cluster image validate
Validates the cluster's update eligibility
The cluster image validate command checks for issues within the cluster that might lead to problems during the update.
[-fields <fieldname>,…​]
[-version <text>] - Update Version
Specifies the ONTAP version to use to validate the cluster.
[-rolling <true>] - Rolling Update
Specify this optional parameter on a cluster with eight or more nodes to perform a rolling-update check. The default is to perform a batch-update check.
Note This parameter is only supported on a cluster with eight or more nodes, and is not supported for two-node MetroCluster.
[-nodes {<nodename>|local}] - Nodes
Specifies the nodes that are to be validated. This parameter is not supported for MetroCluster configurations and for two-stage upgrades.
[-show-validation-details <true>] - Shows All Validation Details
Specify to display all validation details. Default: do not display all details.
[-skip-nodes-at-target-version <true>] - Skip Nodes at Target Version (privilege: advanced)
Specifies that the validation will skip the nodes which are already running target version. Default: true.
The following example shows the validate operation:
cluster1::> cluster image validate -version 9.16.1
It can take several minutes to complete validation...
WARNING: There are additional manual upgrade validation checks that must
be performed after these automated validation checks have completed
successfully. Refer to the Upgrade Advisor Plan or the "What should I
verify before I upgrade with or without Upgrade Advisor" section in the
"Upgrade ONTAP" documentation for the remaining manual validation checks
that need to be performed before update.
Upgrade ONTAP documentation available at: https://docs.netapp.com/us-en/ontap/upgrade/index.html
The list of checks are available at: https://docs.netapp.com/us-en/ontap/upgrade/task_what_to_check_before_upgrade.html
Failing to do so can result in an update failure or an I/O disruption.
Please use Interoperability Matrix Tool
(IMT  http://mysupport.netapp.com/matrix) to verify host system
supportability configuration information.
Validation checks started. Run the "cluster image show-update-progress"
command to check validation status.
The following example shows the validate operation with validation details:
cluster1::> cluster image validate -version 9.16.1 -show-validation-details
successfully.
Refer to the Upgrade Advisor Plan or the "What should I verify before
checks that need to be performed before update.
