ONTAP commands
cluster image validate
Validates the cluster's update eligibility
The cluster image validate command checks for issues within the cluster that might lead to problems during the update.
[-fields <fieldname>,…​]
[-version <text>] - Update Version
Specifies the Data ONTAP version to use to validate the cluster.
[-rolling <true>] - Rolling Update
Specify this optional parameter on a cluster with eight or more nodes to perform a rolling-update check. The default is to perform a batch-update check.
Note This parameter is only supported on a cluster with eight or more nodes, and is not supported for two-node MetroCluster.
[-nodes {<nodename>|local}] - Nodes
Specifies the nodes that are to be validated. This parameter is not supported for MetroCluster configurations and for two-stage upgrades.
The following example shows the validate operation:
cluster1::> cluster image validate -version 8.3
It can take several minutes to complete validation...
Pre-update Check       Status      Error-Action
CIFS status            OK
Cluster health status  OK
Clsuter quorum status  OK
Disk status            OK
High Availability      OK
status
LIF status             OK
LIFs on home node      OK
MetroCluster           OK
configuration status
SnapMirror status      OK
Overall Status         OK
10 entries were displayed.
