Command reference
security protocol ssh modify
Modify the SSH configuration
The security protocol ssh modify command modifies the existing cluster-wide configuration of SSH
[-per-source-limit <integer>] - Per-Source Limit (privilege: advanced)
Modifies the maximum number of SSH instances per source IP address on a per-node basis.
[-max-instances <integer>] - Maximum Number of Instances (privilege: advanced)
Modifies the maximum number of SSH instances that can be handled on a per-node basis.
[-connections-per-second <integer>] - Connections Per Second (privilege: advanced)
Modifies the maximum number of SSH connections per second on a per-node basis.
The following example modifies cluster-wide SSH configuration:
cluster1::*> security protocol ssh modify -per-source-limit 30 -max-instances 60 -connections-per-second 5
