Command reference
volume file clone split load show
Show split load on a node
The volume file clone split load show command displays the corresponding file, LUN or NVMe namespace clone split loads on nodes.If no parameters are specified, the command displays the following information:
  • Node
  • Max Split Load
  • Current Split Load
  • Token Reserved Load
  • Allowable Split Load
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node Name
Node on which the file, LUN or NVMe namespace clone split load is displayed.
[-max-split-load {<integer>[KB|MB|GB|TB|PB]}] - Maximum Clone Split Load
This specifies the maximum allowable split load on the node.
[-current-split-load {<integer>[KB|MB|GB|TB|PB]}] - Current Clone Split Load
This specifies the current on going split load on the node.
[-token-reserved-load {<integer>[KB|MB|GB|TB|PB]}] - Load Reserved for Clone Creation
This specifies the reserved split load of the node using the tokens.
[-allowable-split-load {<integer>[KB|MB|GB|TB|PB]}] - Allowable Clone Split Load
This specifies the available split load of the node.
The following example displays the current and allowable file, LUN or NVMe namespace clone split load on a node.
cluster1::> volume file clone split load show
Node                            Max        Current    Token         Allowable
                                Split Load Split Load Reserved Load Split Load
clone-01                         15.97TB         0B         100MB    15.97TB
clone-02                         15.97TB         0B         100MB    15.97TB
2 entries were displayed.
cluster1::> volume file clone split load show -node clone-01 -instance
Node Name: clone-01
        Maximum Clone Split Load: 15.97TB
        Current Clone Split Load: 0B
Load Reserved for Clone Creation: 100MB
      Allowable Clone Split Load: 15.97TB
