volume file clone split load show
Show split load on a node
The volume file clone split load show command displays the corresponding file, LUN or NVMe namespace clone split loads on nodes.If no parameters are specified, the command displays the following information:
Node
Max Split Load
Current Split Load
Token Reserved Load
Allowable Split Load
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
Node on which the file, LUN or NVMe namespace clone split load is displayed.
[-max-split-load {<integer>[KB|MB|GB|TB|PB]}]- Maximum Clone Split Load-
This specifies the maximum allowable split load on the node.
[-current-split-load {<integer>[KB|MB|GB|TB|PB]}]- Current Clone Split Load-
This specifies the current on going split load on the node.
[-token-reserved-load {<integer>[KB|MB|GB|TB|PB]}]- Load Reserved for Clone Creation-
This specifies the reserved split load of the node using the tokens.
[-allowable-split-load {<integer>[KB|MB|GB|TB|PB]}]- Allowable Clone Split Load-
This specifies the available split load of the node.
The following example displays the current and allowable file, LUN or NVMe namespace clone split load on a node.
cluster1::> volume file clone split load show
Node Max Current Token Allowable
Split Load Split Load Reserved Load Split Load
clone-01 15.97TB 0B 100MB 15.97TB
clone-02 15.97TB 0B 100MB 15.97TB
2 entries were displayed.
cluster1::> volume file clone split load show -node clone-01 -instance
Node Name: clone-01
Maximum Clone Split Load: 15.97TB
Current Clone Split Load: 0B
Load Reserved for Clone Creation: 100MB
Allowable Clone Split Load: 15.97TB
