Command reference
vserver vscan scanner-pool servers show
Display list of servers
The vserver vscan scanner-pool servers show command displays the list of servers of the Vscan scanner pools belonging to the Vserver. If you do not specify any parameters, the command displays the following information about all scanner pools:
  • Vserver name
  • Scanner pool
  • List of servers
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the scanner pools for the specified Vserver.
[-scanner-pool <Scanner pool>] - Scanner Pool
If you specify this parameter, the command displays information only for the specified scanner pool.
[-servers <IP Address>,…​] - List of IPs of Allowed Vscan Servers
If you specify this parameter, the command displays information only about the scanner pools that have the specified IP address or IP addresses.
[-hostnames <text>,…​] - List of Host Names of Allowed Vscan Servers
If you specify this parameter, the command displays information only about the scanner pools that have the specified host name or host names.
The following example displays the list of servers of all scanner pools.
cluster1::> vserver vscan scanner-pool servers show
Vserver         Scanner Pool      Servers
vs1             SP                1.1.1.1, 10.72.204.27
vs2             p1                10.72.204.29
6 entries were displayed.
The following example displays the list of servers and host names of all scanner pools.
cluster1::> vserver vscan scanner-pool servers show -instance
Vserver: vs1
                               Scanner Pool: SP
       List of IPs of Allowed Vscan Servers: 1.1.1.1, 10.72.204.27
List of Host Names of Allowed Vscan Servers: 1.1.1.1, vmwin204-27.fsct.nb
Vserver: vs2
                               Scanner Pool: p1
       List of IPs of Allowed Vscan Servers: 10.72.204.29
List of Host Names of Allowed Vscan Servers: vmwin204-29.fsct.nb
2 entries were displayed.
